I'm planning a GM70 build, and am now looking at output transformers. The B+ voltage would be at 1000V (maybe 1050) from 800VAC.
I was thinking of getting a James JS6123, but I found a thread where the manufacturer says its not appropriate for 813 tube, even though its rated at 1000V max. In fact, they even said its only appropriate for 300B and similar tubes. Then I contacted Edcor and asked for a 1200V OT, but they said they cannot do > 1000V .
Of course there's ElectraPrint, Hammond 1628SEA, and the James 6135 which can do GM70 type tubes. And I will go for one of those for safety's sake.
But then there's Pete Millett's 813 , which uses a Tango XE20 which is also rated at 1000V and he uses it at least 800V, close to spec.
So for my enlightenment, what will happen if a 1000V OT is used at 1050V?
