what dac would i need for the marantz cd6003
In my humble opinion, I think you should visit your local dealer and find out if you can audition some cables - go for good interconnects - something like Van Den Hul or some equivalent. However if your mind is set on a dac check out this site for some suggestions.
what dac would i need for the marantz cd6003.
The answer is none - you don't need a DAC for that player as it contains its own DAC. Perhaps this is why nobody answered the question. Assuming the player has the usual SPDIF output then an alternative answer is 'any DAC which supports SPDIF' (i.e. almost any DAC). I don't understand your reference to USB; maybe someone else will.
If for some reason you wish to use an alternative DAC then you could either ask for people's preferences or say why you want to use an external DAC.
