I have a lm4702 2sc5200 1943 pair amp. I have measured in room using a RTA with berdynamic mic.. we were playing through sony laptop which sound ashtonishingly good but we have seen a rolloff from 14khz to 20khz
im using vifaxt25sc ring radiator using a first order crossover but used a first order crossover with 28 .47uf in parallel to achieve the capacitor.
is the rolloff because of the possibilities..
1. the amp has a 7uH inductor approx ( 10 turns of 5mm dia 1mm thick coil ) at the output
2. the capacitors in parallel are making effective inductance because of leads ( infact they have to get reduced coz they are in parallel)
3. the mp3 320kbps format might not have enough HF information
4. Do room acoustics play role ( since we have kept the mic on axis at 1m)
i would like to know that is the inductor at the otuput makes any difference?
what if its removed? any problems? could the rolloff be happening because of that?
