Not completely sure, but i imagine that BD139/140 will fit, or the small transistor
BC639 and BC640, that is the same transistor made smaller.
The BC639 can dissipate 1 watt only, can hold 1 ampere..... do not believe...better to believe 500 miliwatts.
The BD139 can hold 1.5 amperes, dissipation (real) is around 8 watts only, and can work in Radio frequency transmitters, up to 30 Megahertz without problem...so, the - 3 dB roll of will be not a problem to you
The gain is around 150.
I think will match your needs...let's listen to more forum friends.
They can correct me, if i am wrong.
regards,
Carlos
