What are the recommended methods to connect:
1. A Shiva driver to an AVA-250 amp
2. My receivers subwoofer out RCA jack to the amps jack(s)?
For #2, would a simple RCA cable with single jacks on each end
suffice, or do I need a Y-type cable to connect to two amp jacks?
Grant
Grant
Thanks for the reply Super, but what you replied to in my "Will an amp significantly alter box volume??" thread, was #1 and not #2 as you had mentioned. To answer my own #1 question, I believe it's recommended to wire (solder? or spade?) the voice coils in parallel and connect (solder? or spade?) the pos/neg wires to the corresponding locations on the amp.
As far as #2 goes, what benefit does your wiring method have over simply connecting the receiver sub-out to the left amp jack
with a basic RCA cable?
Grant
Grant
