What are the options for customizable rear panel
I see that option now! Thank you!!
I was going through other options and found an aluminum rear panel as an add-on for Dissipant. Would that be customizable as well? If so, I can have two back panels -- one that comes with the case and this additional one.
Edit: These blank aluminum back panels will suit all Dissipante and Deluxe chassis that have aluminum rear panels (not compatible with steel rear panels).
Can anybody recommend a software to design Front panel with depth information for recessed holes? I need to drill recess for knobs around volume control shaft.
Front Panel Designer can export to DXF format and it can create cavity on the panel. Would that be sufficient?
