Wharfedale Opus Tri Surround Speakers $250
Company Maketing Below.
The Wharfedale Opus loudspeaker system is a premium quality, large format loudspeaker designed for exceptional accuracy in the reproduction of recorded music and film.
Numerous new technologies have been applied throughout the range to ensure that Opus is capable of creating a lifelike listening experience akin to that of a live concert hall. New Carbon-Fibre bass drivers, our unique tri-laminate cone, three-inch dome mid-range and a lightweight ‘copper-coated’ aluminium tweeter voice-coil for extended and precise high-frequency response, all contribute towards one of the finest loudspeakers available today.
Build and finish is nothing short of exceptional. The Wharfedale Opus series fit effortlessly into the living environment with real wood veneers - not reconstituted woods. Gold-plated terminals real construction which utilises variable-density multi-layer laminate MDF cabinets, sealed and isolated mid-range compartment, high-purity oxygen-free copper cables.
Drive Unit Technology: Opus uses advanced neodymium and alnico magnets to produce intense and focused flux fields that provide a tight grip on drive unit movement. The soft dome midrange, provides tonal balancing throughout the range. The bass cone, a woven carbon fibre composite unit exhibits incredible linearity and control with a textbook response and rise time. Dynamics are dramatically harder and faster with no noticeable bass overhang.
Opus ‘Tri-pole’ Surround: Twin pairs of dome mid-ranges and tweeters fire at angles. This speaker is designed to be hung on rear or side walls in pairs to create the ideal rear soundstage for modern multi-channel systems. The front firing 6.5” or 170mm bass driver extends the bass response to around 60Hz.
Gold-plated Terminal & Spikes: Heavy duty, shielded and gold-plated tri-wire terminals are supplied. Bridge links for either single, bi or tri wiring, enable a wide choice of amplifier and cable options to suit every budget and taste.
Wharfedale Opus Tri Surround Speakers - Performance Specifications
• Type Tri-polar surround speaker - wall mount
• Bass driver: 6.69" KEVLAR
• Mid-Range: 2 x 2.95" Textile Dome
• Tweeter 2 x 25mm Textile Dome
• Nominal Impedance 6ohm (8ohm compatible)
• Frequency Response +/- 3dB 60Hz - 43kHz
• Recommended Amplifier Power 40 - 200w
• SPL (1w@1m) 89dB
• Dimensions 11.02" H x 18.11" W x 7.09" D
• Net weight 23.37 lbs
• SOLD as PAIR
