Warfedale Kingsdale 3
Administrator
Joined 2007
If you are just after getting something to work then CPC in Preston carry a range of drive units. It would be up to you to determine if you could mount it in the cabinet.
This is just one:
MCM AUDIO SELECT - 55-2974 - 15" 200W 8R Polycone Driver | CPC UK
Getting a driver of the same characteristics as the original will probably be almost impossible. What that means is that fitting a different type will almost certainly sound 'different' to the original in some way. They will certainly work though.
