Wanted to trade f4 boards for f5
pics
Heres my dillema guys
i already have a f6 kit on the way so will already have some of that sweet transformer flavour in my house
so i guess i,m looking for somethoing different to add to my stable
i also have a complete set of running aleph 2 boards to trade as well if some one is interested they are built with nichicon caps matched semis and dale resistors
i could be partial to a trade on some pre amp boards as well
cheers Sheafer
gday all
still have the aleph 2 boards
complete and working ,all good parts used with tec diy matched semis
i will bundle them with 2 x nuvotem potted 500va25/25 trannys
for $300au the lot
these are very good trannys all you will need to have a working aleph 2 is power supplys
they are high bias so you will need conrad 151/350 sinks in mono blocks minimum but the sound is magnificent
the above is setup to run harder speaker loads hence the lower supply voltage/higher bias
i can supply the sinks for extra cost shipping to au only as the trannys are very large and heavy
still will consider swaps
forgot to add sorry 3g the f4,s are gone
sheafer
Let me test a couple of options and Ill let you know. You can bypass the input on the F4 the BA FE without doing anything else other than connecting it in proper place. I am after dropping any coupling caps, through a balanced variation.
