Can anybody give a 150 to 200 watts amplifier schematic?
Or just teach me how to bridge 2 pcs DX amp, because I have one, but i'm not using it anymore because cant push my 12" subwoofer to its limit.![]()
There is a substancial difference for Amplifier 150-200 Watt RMS into 4 Ohm
and the same into 8 Ohm.
But if nothing else is told, we will assume you talk normal 8 Ohm.
Subwoofer/Bass amplifiers have some special features.
And should be able to output heavy current peaks.
It is always better to use a dedicated Bass amplifier for subwoofers.
see the attached file, this may help you. if helps please let me know..Can anybody give a 150 to 200 watts amplifier schematic?![]()
Hi my subwoofer is 6 ohms, i have used ESP's subwoofer processor with the dx amp but cant still push my subwoofer to its maximum excursion,
And when i try to play it at full range the sound is clipping. idont know why?
What is YoYo's intention?
Do you want to build a 150W into 6r0 amplifier for your own use?
or
do you want us to supply all the information so that you can go into production and make a profit without any capability to service your customers?
Your blog shows 2955/3055 for outputs. Do you have the datasheet?
Have you any information about your output devices?
or
Hi Can you give me the schematics of that design?
Thamks for your post!!!!!
Schematics available here: Nmos200 - Quasi's DIY Audio Site
Cheers
Quasi
- Wanted , Simple 150 to 200watts amplifier
