would you settle for td12x apollos
? they make a great vented woofer/midwoofer tuned to 35 Hz. Augerpro has posted measurements of both and the 12X looks every bit as good as the 12M and has twice the Xmax
I have a pair; one brand new factory box never opened. one spent a few hours in a proto box and was tested lightly
edit: 4 ohm Z
edit: 4 ohm Z
would you settle for td12x apollos? they make a great vented woofer/midwoofer tuned to 35 Hz. Augerpro has posted measurements of both and the 12X looks every bit as good as the 12M and has twice the Xmax
edit: 4 ohm Z
thanks for your offer but i found some td15m and will use those for my project .
