Greetings, I have four pieces of rackmount equipment that require 200-600ma of 18VCT AC power, and each piece comes with a large wallwart that takes too much room and well as cause other neatness issues. I’m not sure I’m thrilled with the idea of daisy chaining them off one large(r) transformer, but am toying with the idea of housing four chassis mount transformers in my rackmount power conditioner (lots of dead space inside). Other than mounting the cores at right angles to one another, are there any other tips/recommendations/arguments to this idea?
The OEM powersupplies are nothing more than an EI transformer with fuses on each secondary, is there anything that could/should be changed or improved upon from the OEM methodology?
Thanks & take care!
Thanks & take care!
