I'm experiencing a low frequency persistent thumping from my speakers and a significant intermittent thump from my subwoofer when adjusting the volume to my preamplifier.
It began a few days ago when I changed out the output coupling capacitors to my dac. I did so in hopes of improving the clarity to my system, I changed the value from a 2.0uf to a 3.9uf. I changed the capacitance value due to the recommendation of a vendor, as my premaplifier has an input impedance of 10k, and it was recommended that a higher value capacitor may be better for my system. I found similar information using the V-cap calculator, as it indicated an optimal capacitor would be much higher than the stock value. I settled with the 3.9 value due to space constraints.
Upon changing the capacitors, I immediately heard the thumping in the system. Once the volume was changed, the sound was very good. However, the volume adjustment noise bothered me so I investigated my connectors. This led to what I thought was a discovery, as I noted the left rca output of the dac was creating a noise through my speakers when disconnecting and connecting. I followed up by purchasing a new set of rca jacks, I soldered them in tonight, and I'm still experiencing the thumping when adjusting the volume.
Curious what I should be looking at for a fix? Is this a problem with my preamplifier's volume control? Or is it the dac? Or something else entirely, perhaps?
Any thoughts would be greatly appreciated.
