Hi, I'm restoring a Voice of Music 1428 Tube Amp and found the incandescent power indicator is burnt out. The Sams schematic doesn't specify a part. Per the attached schematic it runs to the center tap of the 6 Volt filament transformer witha 10 ohm series resistor. Can anyone suggest a replacement bulb or LED combo for this bulb? Since this indicates power in a high voltage amp I want greatest reliability which may be an LED.
thanks
thanks in advance
thanks
thanks in advance
I'm pretty sure the original is a #47. Antique Electronics sells LED replacements:Can anyone suggest a replacement bulb or LED combo for this bulb?
https://www.tubesandmore.com/products/dial-lamp-led-version-47-or-44-t-3-63v-bayonet-base
Thank for the reply, but its a small glass bulb nor more than 1/8" in dia with leads coming directly from the bulb.
Thanks very much.That looks fine mechanically, however I guess I'd have to experiment to see how it would perform at the 3 Volts supplied by the circuit.
Ok, what you have is known as a grain-of-wheat bulb. These are T-¾ size lamps. Many of them are 5v at 60ma. But they also come in 12v and perhaps lower then 5v. Since yours is connected through a resistor to ½ the 6.3v filament voltage, they're probably low voltage. Perhaps get some 5v lamps and operate it from the 6.3v through a suitable resistor. Or just the 3.15 half as shown. Lamps operated at 10% lower then rated voltage last a very long time.
A few more voltages. You could buy one of each.
https://www.allelectronics.com/category/320700/lamps/miniature/grain-of-wheat-lamps/1.html
Thank you. I should be able to find a 4.5 Volt grain wheat bulb and run it off the 3 Volts as suggested for longevityOk, what you have is known as a grain-of-wheat bulb. These are T-¾ size lamps. Many of them are 5v at 60ma. But they also come in 12v and perhaps lower then 5v. Since yours is connected through a resistor to ½ the 6.3v filament voltage, they're probably low voltage. Perhaps get some 5v lamps and operate it from the 6.3v through a suitable resistor. Or just the 3.15 half as shown. Lamps operated at 10% lower then rated voltage last a very long time.
The bulb needs to operate at 3 Volts, that one operates at 12.
See post #7.
Thanks,
That is very similar. I ordered a 5 Volt version and will see if its bright enough. If not I can try a 4.5 Volt one I found at another vendor I found a place with a 4.5 Volt too. https://www.miniaturebulb.com/28s.html
Do you see any issue using a 5 Volt one off the 3.1 Volt tap? Bulb in question is: 5 Volt, 115 mA Grain of Wheat BulbOk, what you have is known as a grain-of-wheat bulb. These are T-¾ size lamps. Many of them are 5v at 60ma. But they also come in 12v and perhaps lower then 5v. Since yours is connected through a resistor to ½ the 6.3v filament voltage, they're probably low voltage. Perhaps get some 5v lamps and operate it from the 6.3v through a suitable resistor. Or just the 3.15 half as shown. Lamps operated at 10% lower then rated voltage last a very long time.
I don't see any problem with it as long as your PT handles the extra current drain. And it should be able to. Hopefully the intensity is bright enough. Personally I would use a 60ma version lamp, but you'll just have to try the 115ma bulb and see.
- Tubes / Valves
- Voice of Music 1428
