VN2410 MOSFET metal TO-92 (TO-39 or -66) pinout?
Hi all,
I am working on a design that needs a small-signal MOSFET and I have a bunch of NOS VN2410(A)'s that would fit perfectly. But they are in a vintage metal TO-92 case (one pin connected to the case) instead of the common plastic TO92.
Does anyone per chance know the pinout of that case? Looks like TO-39 or TO-66
Jan
They are metal TO92.
http://www.futurel.bg/datasheets/4/VN2410.pdf
Same pin out as plastic.
Jon, yes, but the pin-out is not really the same. The pins are in a semi-circle and one is connected to the metal case. I have found other similar and it appears the pin connected to the metal case should be the drain.
I could then guess that the middle is the gate, but I'd rather have some confirmation of that.
Maybe I should just measure it.
Jan
