I just aquired some drivers. I am hoping I can use them to build nearfields. There are no #s on them
The woofers are 8" , paper with a cast aluminum basket. approx.2" vc
The tweeters are heavy steel with a purple pol ish dome wit a plastic cover. Apparently they were two way.
Can anybody recommend a sealed enclosure for these or lead me in the right direction for finding out best configuration.
Thanks a million
Thanks a million
If you can post a pic or two, someone might be able to identify the drivers for you. Without knowing, it will be really tough to get the box right. Kind of a hit and miss thing. Did you happen to scoop the XO too?
Cal
Cal
