Anyone know anything about this thirty year old tube tester? As far as I can tell, it was made in 1979, but how useful does one think this tool is as far as tube testers? It is an alnico ft 435.
Nobody knows? As far as I can tell if the little light cuts on in the tester the tube is fine. This is a vague way of testing though isn't it?
After applying the art of search engine driving, I found that the company is not alnico, it's Antronic:
FT- 435 Radio Antronic Corporation
Unfortunately, that's all I found on it, and it looks like nothing you don't already know. And yes, offhand it looks like this does very little if anything useful as far as testing tubes, perhaps just testing for conductivity in the filament, something you can do with any ohmmeter.
And I question calling something "vintage" relative to tubes when they were already very well obsolete by the date you give for it, 1979. This would be a "modern" tube tester, or even one of the last such made.
That tester is pretty worthless. It only shows if the heater is good, and an Ohmmeter can do that. Save it as a relic of the past. I guess it has a buzzer or something to tell if there is continuity.
You want to test tubes, you have to measure plate current and of course with real voltages applied.
Benb I question it as well, that is why there is a question mark at the end of the title..
