I have a pair of 2 way bookshelf speakers and one of the tweeters was physically damaged by my friends kids.
I opened it up the speaker adn teh tweeter is a vifa D20TD-05-06 3/4 soft dome. I think it is available but i would not mind upgrading the tweets in both speakers.
I am open to suggestions but want to stay below say $45 dollars each tweeter.
D20TD-05-06 specs
Voice coil resistance [ohm] 4.2
Sensitivity [dB] 89
6 ohms *DC resistance: 4.2 ohms *Fs: 750 Hz *SPL: 89 dB 1W/1m Free air resonance [Hz] 1700
I was already planning on building new cabinets for these speakers so it does not have to match in size.
According to the manufacturer my speakers are crossed over at 2500Hz
i was looking at PE site and there are some 1 inch soft domes i thought i could try.
like VIFA PL27TG-35-06
6 ohms *DC resistance: 4.6 ohms *Frequency range: 1,500-25,000 Hz *Fs: 750 Hz *SPL: 91 dB 1W/1m
Could i just pad this down a bit to because of its greater sensitivity? Or does its higher DC resistance cause more problems.
the tweeter section of the crossover seems simple with a 3.9uF cap in series and an inductor parallel. not sure of the inductor value i will try to get them measured.
good ideas or suggestions apreciated.
D20TD-05-06 specs
Sensitivity [dB] 89
