Hi
I´m trying to measure temperature with my PC audio card. To do so, I have a 555 chip 0,5Khz oscillator, and a filter to change square wave into a sinusoidal one. A calibrated thermistor changes its resistence so oscillation frequency changes.I capture "sound" on my Linux machine.and use a special Linux library to extract "pitch" (main tone) from the signal in real time.It can easily detect small frequency changes due to temperature change.
But...I see my 555 has erratic frecuency changes of +/- 20Hz and more at higher frequencies.
So...do you know how a 500Hz stable audio oscillator can be built?.A Wien oscillator could do the job?
Thank you DF96.
My window is 256, but I´ve tested also 1024.I´m sampling at at 44100Hz with 16bit samples.Then, I take an average each 200 samples. If I use the same program to sample a 1khz wav file generated with a program, it perfectly matches the frequency within +-1Hz.
Have you bypassed the modulation input pin. The other issue is what type of timing capacitor and resistor are you using.
The 555 output stage had a reputation of taking a high transient current during switching so plenty (micro farads) of decoupling capacitance is needed.
Jim Williams did a few high performance V-F converter articles spread over National (now TI) and Linear Technology app notes
Capacitor is ceramic one.I have a carbon potentiometer to select 50% duty cicle.
I´ll check datasheet about MAX6577, as mickeymoose suggested.
I checked MAX6577...Too low accuracy...It seems good to monitor an electronic device board but not for measuring temp below 0.1ºC accuracy.
I meant time window, but I guess I can estimate it from your figures. 256 samples at 44.1kHz means a sampling window of around 9ms, so each individual measurement could be out by about 110Hz. Averaging a regular set of measurements sounds fine, unless you are unlucky and still get an average which is way out.po210 said:My window is 256, but I´ve tested also 1024.I´m sampling at at 44100Hz with 16bit samples.Then, I take an average each 200 samples.
Much better to sample more slowly. To get an accurate frequency measurement of 500Hz you need a window of at least a few seconds.
Depending on exactly how you did this, you may be ensuring that the 'generator' and 'frequency meter' are always exactly in step with each other.If I use the same program to sample a 1khz wav file generated with a program, it perfectly matches the frequency within +-1Hz.
- General Interest
- Everything Else
- Very stable audio oscillator?
