Hi!
Now, I have a pair of old SEAS 13" woofers in good condition which i intend to use for a 3-way active design.
Now, I have a calculation program (CAAD 3, an old freeware application)
which I have been using just for playing around a little.
Now here's the issue; According to the calculations, the ideal box size is around 170 L, giving a -3dB of around 35 Hz.
In terms of low frequency, this is where I would be happy to end up, so that's OK.
I am however a bit puzzled about the cabinet size, as the original SEAS datasheet quotes: "closed box 50-100 L" and "Bass reflex 70-100 L"
170 L is obviously a lot more than the guidelines provided by SEAS.
I have tried tweaking around with the program, and for a vented box with a volume of 100 L, I can obtain a -3dB of 42 Hz. with a linear response.
Ok, but not great for a 13" driver with a Fs of 27 Hz....
My first assumption is that a 170 L box with a -3dB of 35 Hz is a theoretically extreme application of the driver not considered a "real world" application by SEAS.
My second thought is that the driver could well be capable of delivering very low frequency response in a 100 L vented box, but that the software I'm using is somehow not quite appropriate.
Any views and comments from those of you with practical experience with using box calculation software would be greatly appreciated.
Best regards,
http://www.seas.no/images/stories/vintage/pdfdataheet/h175_33fzbxdd.pdf
Best regards,
Hi Elbert,
Unfortunately, with a Vas of 270 L, your software seems to be giving you the right answers....
But, because you're going active, you could consider using them in a sealed enclosure with a Linkwitz Transform circuit:
http://sound.westhost.com/linkwitz-transform.htm
Mass loading..
Hi Pete!
Thanks for taking the time to reply!
First of all, good to know that my software is probably adequate, that gives me some reassurance regarding my baseline here....
I've always been a bit skeptical about equalizing in this ways due to the sacrifice in maximum SPL level, but the reasoning on power distribution VS frequency certainly has something going for it, so it might be an option after all.... or I could simply build a 170 L vented enclosure!
But then I tried something interesting, in my driver file, I increased the moving mass from 45 to 80 g, and this yielded an interresting result.
I could now get away with a vented enclosure of only 102 L still obtaining a -3dB frequency of 33 Hz. The only evident tradeoff was an overall loss in efficiency of 2dB, leaving em with 91 dB/w/m which is still fine by me!
I guess the higher frequencies might suffer from this, but as I'm aiming for a pretty low x-over here anyway (typically 150-200 Hz), this shouldn't be a problem.
A 100 L box would be preferable over one of 170 L..
Are there any other issoes or problems with mass loading a driver I need to be aware of?
Hi Pete!
Looking at the spec sheet, the driver has a high sensitivity. That means high BL, that means well-damped. Well-damped means that the f3 is going to be significantly higher than fs for any sort of flat alignment. It's really more of a midbass driver, which is consistent with the voice coil height/air gap spec (not super impressive Xmax).
I'd use a small enclosure and accept the high f3 OR a very large one to overdamp and use boundary reinforcement to bring up the low end.
Your software is telling you the truth.
Hmm...
I suppose that the software you use does not give you actual response curves? If so, there is a risk that you stare too much at the -3 dB point that the software so happlily spits out.
There are other free softwares that will give you a response curve instead, and in this case I think that I would go for a BR of ~90-120 litres tuned to 25-30 Hz.
This will give a slightly sloping response towards lower frequencies and this will fit nicely with the room gain.
You could try Basta! in my signature if you like.
jnb said:In order to achieve acoustic suspension, your box should be less than a third of Vas. In an ordinary design, this rule of thumb sets your box at 100L or less.
Your Qt in the closed box ought to be higher than 0.5. This also suggests a box of this size.
Curious, I hadn't heard this rule of thumb. Care to elaborate on the 'why'?
Hei Svante!
Yes, my software actually plots a response curve, and so far I've been aiming for a flat response......
Your point about allowing for a slightly sloping response and to have it "compensated" by the room response is very interesting!
But then again, how does one predict the room response? And what might turn out to be right for my current living room might be completely wrong if (when) I move to another house.... that's the tough one with low frequency audio, the source and the room is really part of the same equation....
The best bet is perhaps to go for a reasonably flat response and use an equalizer for tuning to what ever room they might end up playing in?
Re: Mass loading..
Greets!
Hmm, using the posted specs I get a 100.08 L, 34.5 Hz F3 T/S max flat half space vented alignment and since this keeps it from exceeding the calculated Xmax enough to matter it's a reasonable recommended max Vb.
That said, this alignment tends to sound 'boomy' in many home layouts, so tuning it down around Fs in as much as 150 L seems a better choice overall.
WRT mass loading for LF/sub duty, i.e. limited to its pistonic BW (~414 Hz), no real downsides besides the efficiency loss as long as the mass loading is done in such a way as to not damage the suspension.
GM
Greets!
GM
Hi GM!
Interesting your comment about space alignment... I somehow suspected this to be of relevance with regards to a vented box being smaller than the theoretical value i get with my software (which really doesn't have any specific input or options for alignment"
Regarding Mass loading, from what you're saying it seems like I'll be fine as I'm planning to use these woofers for pure "sub-woofing" duty anyway!
Guess I'll explore that avenue a bit further then...
Elbert, yes.
Mass loading may give nice-looking models, but needs to ba approached with great caution. Getting a lower small-signal f3 does not increase travel and power handling- remember that you need four times greater displacement at 20Hz as 40Hz. I'd still recommend using this driver for what it was intended- a high-efficiency mid and upper bass driver, not a subwoofer.
SY,
You are of course correct in your observation that a lower F3 obtained by means of mass loading will still require more amplitude to maintain SPL, and I fully agree that this would be a dubious approach.
But if I use some mass loading to obtain a similar F3 in a smaller box (e.g. 100L) as i would obtain in a larger (e.g. 170 L) box without mass loading, wouldn't this be ok? except of course for the reduction in upper frequency, which is not a problem in my case anyway?
Or did I miss something out completely here.....
Svante said:There are other free softwares that will give you a response curve instead, and in this case I think that I would go for a BR of ~90-120 litres tuned to 25-30 Hz.
svante if i chose that i will chose 120 L tuned to 25-30 L a slightly sloping response at low frequencies have a litle.
yeah why do they offline at all.
Efficiency, power handling (as a function of SPL), and Q will all be different, no?
- Very large enclosure issue...
