...for use in differential pairs. Let's say our criteria are as follows:
1. TO-92 case (or similar). No dual parts, such as a 2SA798.
2. Usable Vceo, 65V or better.
3. Minimum Ic of 50mA.
4. Reasonable bandwidth, 100MHz min.
5. Being in current production would be nice, but otherwise reasonably easy to find.
The best I have found:
Fairchild KSA992. Consistant gains of between 410 ~ 470 @ 1mA.
Zetex ZTX795A. High gains, typically between 510 ~ 575 @1mA, with the occasional device measuring a bit over 600.
Fairchild BC556C. High gains, usually better than 500, but all over the map, from 500 to 650 or so. I always find it a pain to match a pair of devices with these.
A while back, I pulled a few TO-92 PNP transistors from an old 70's Japanese amp, and out of curiosity measured gain. Of the eight devices, the lowest one measured about 750 @ 1mA. All were fairly close to that. I meant to write down the number, but I can't now find the devices, or remember the number. I'm sure they were long out of production, but I wish I could remember what they were. Maybe the best devices were in the past...
Any devices I'm missing? Love to hear your thoughts.
Hitachi 2SA1085E... those are getting scarce, unfortunately. And maybe a bit on the low side regarding ft and usable Ic, but low noise and low Cob.
- Klaus
- Klaus
Yes, those are very good, but tough to find.
B&D gives a cross to the Sanyo 2SA1016K, and if you can find the 'H' gain group, it promises gains from 480 to 960(!).
EchoWars said:...for use in differential pairs. Let's say our criteria are as follows:
2SA970 BL are pretty good and readily available.
120V / gain 350~700 / 100mA / 100MHz. All the ones I had on hand
measured gain >400.
cheers
Terry
Thanks Terry!
I had forgotten about the Toshiba 2SA970. I have a couple dozen of them, and a quick check shows gains between 515 and 530. Not bad.
But...I'd love to find something with consistant gains of >600.
EchoWars said:Thanks Terry!
No worries.
If I may ask, why do you need such high beta?
cheers
Terry
a872
a970
a992
a1015
a1016
a1083/4/5
b715/6
and a couple NPN that I can't find complements for
c1845
c3068, only 25Vce0
and finally
d755/6
a970
a992
a1015
a1016
a1083/4/5
b715/6
c1845
c3068, only 25Vce0
and finally
d755/6
is the 2SA872A series still available? i haven't bought any in a while. they might be useful here.
mlloyd1
mlloyd1
neither of my NEC datasheets for the a992 & c1845 refer to the other as the complement.
Hi
Fairchild makes similar devices except they name it with a K instead of a 2. They do this with all their typical transistors.🙄 Anyway, they list them as complements in the datasheet
Nice, high input impedence, low base currents, low offsets.Terry Demol said:
No worries.
The original '2S' numbers were properly assigned to the Japanese manufacturers by the JIS (Japanese Industrial Standard) council. Fairchild chose to label them as 'KS' to distinguish them as replacement parts with similar specs without stepping on the JIS system.CBS240 said:
Hi
Hitachi shows them as a current product, and B&D carries them. Good typical gains, but not as good as the Zetex ZTX795A or Toshiba 2SA970BL.mlloyd1 said:is the 2SA872A series still available? i haven't bought any in a while. they might be useful here.
mlloyd1
Cant help with pnp parts yet but if you looking for npn s try 2sc3495, these parts are excellent. 😉
From a newly recieved batch of 1000 trannies only 23 were below 1000 hfe.
StevenOH said:Andrew,
2SA992-2SC1845
2SC3068 was developed without a compliment.
Wrong, here you go, 2sa1240 been using them for more than 15 years. 😉
EchoWars said:5. Being in current production would be nice, but otherwise reasonably easy to find.
Glenn,
how about the Mitsu/Pana A979H and C2259H duals with a Beta of 600-1200.
As if you've never had Pioneer or Marantz items on your bench.
Obsolete, but still easy to find and surprisingly cheap.
(for 50V : Panasonic A798G )
Perhaps you typed that number in wrong? The 2SA1240 is s dual part in an oddball six-pin package.homemodder said:
The A979 is one I've been looking to find in quantity for a reasonable price ($1 or so). I can get pieces here and there for prices between $3.50 and $10 each, but I'm looking for something like 100 of them, and not interested in shelling out stupid prices for them. Glad I don't need them too often.jacco vermeulen said:
Glenn,
I have a bunch of the A798 F & G, and they work very well when I can use them.
I'm looking for TO92 NPN transistors to replace LM394H, gain 550 @ 10 uA, any ideas, preferably with ECB config?
I don't think so. LM394 is a multiple transistor, with many parallel transistors formed on the one substrate to achieve otherwise impossible matching by virtue of averaging the individual junction properties.
You won't get anywhere near that match quality or low drift without extremely precise matching of duals, also on the same substrate. Then again, if you don't really need the "supermatch" properties, you may find these useful, if also obsolete: http://www.analog.com/static/imported-files/data_sheets/SSM2210.pdf
http://www.analog.com/static/imported-files/data_sheets/MAT02.pdf
You can still obtain LM394H if necessary - there are a few realistic opportunities on the net with a little help from Google. However, this recently revised doc. by TI suggests some renewed manufacturing interest: http://www.ti.com/lit/an/snoa626b/snoa626b.pdf
- Very High-Gain PNP Transistors...
