I am in the process of designing subs cabs for pro sound use and need the optimal balance between cab size, spl output, quality of sound and ease of construction. The final choice is between a Vented QB5 filtered alignment vs a TH. Aiming at an F3 of around 35Hz and driver choices are yet open.
Which do you think will provide the best balance most benefits......Opinions suggestions discussions are welcomed
The optimum trade-off between bass extension, box size and efficiency is with a Qts=0.312 and a 6th order vented design with Fs=Fb=Faux with a Q=2 filter for Faux.
A 2 cu ft 2nd order sealed box with an F3 of 30hz can only be 0.18% efficient (84.55dB).
A 2 cu ft 4th order vented box with an F3 of 30hz can only be 0.36% efficient (87.56dB).
A 2 cu ft 6th order vented box with an F3 of 30hz can only be 0.90% efficient (91.54dB).
Eminence Kappa Pro 15LF-2 (or similar):
http://i56.photobucket.com/albums/g196/dkleitsch/x-1.gif
A small PA:
http://i56.photobucket.com/albums/g196/dkleitsch/sub-2way2.jpg
A compact high output PA:
http://i56.photobucket.com/albums/g196/dkleitsch/CoePA-2009.jpg
The Kappa Pro 15LF-2 is -3dB at 35hz in the design shown, and four cabinets can be built from five sheets of 4x8. The design is 104dB/2.83V/1M mid-band (and a 4Ω load). The PPSL has about 20dB less 2nd harmonic distortion that a normal reflex box. Will handle 1200W (sine) at 4Ω without exceeding x-max, more on actual program material.
Driver Properties
Name: Kappa Pro-15LF-2
Type: Standard one-way driver
Company: Eminence Speaker LLC
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 35 Hz
Qms = 7.3
Vas = 198.8 liters
Cms = 0.191 mm/N
Mms = 108.3 g
Rms = 3.263 kg/s
Xmax = 6.7 mm
Xmech = 18 mm
P-Dia = 330.2 mm
Sd = 856.3 sq.cm
P-Vd = 0.574 liters
Qes = 0.32
Re = 6.5 ohms
Le = 1.4 mH
Z = 8 ohms
BL = 22 Tm
Pe = 600 watts
Qts = 0.307
No = 2.568 % (one driver)
2.83V (2W at 4Ω) SPL = 104dB (150hz)
Box Properties
Name:
Type: Vented Box w/ Active HP Filter
Shape: Prism, square (optimum)
Vb = 6 cu.ft
Fb = 35 Hz
QL = 6.087
F3 = 35.19 Hz
Fill = none
No. of Vents = 2
Vent shape = rectangle
Vent ends = one flush
Hv = 10.87 in
Wv = 2.5 in
Lv = 16.71 in
Active 12 dB/oct. HP Filter
Fx = 35 Hz
Qx = 2
A small PA:
Driver Properties
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 35 Hz
Qms = 7.3
Vas = 198.8 liters
Cms = 0.191 mm/N
Mms = 108.3 g
Rms = 3.263 kg/s
Xmax = 6.7 mm
Xmech = 18 mm
P-Dia = 330.2 mm
Sd = 856.3 sq.cm
P-Vd = 0.574 liters
Qes = 0.32
Re = 6.5 ohms
Le = 1.4 mH
Z = 8 ohms
BL = 22 Tm
Pe = 600 watts
Qts = 0.307
Box Properties
Name:
Vb = 6 cu.ft
Fb = 35 Hz
QL = 6.087
F3 = 35.19 Hz
Fill = none
No. of Vents = 2
Hv = 10.87 in
Wv = 2.5 in
Lv = 16.71 in
Fx = 35 Hz
Qx = 2
