I have 4 pcs of UM-15 DVC Ultimax wich is going to be installed in my home cinema room.
Room is about 6000 x 5000 x 2500 mm
Will use it mostly for blu-ray concerts , rock, powermetal etc
Want to feeeeeeel bass in chest!
Amp i have is iNuke 6000DSP.
Most people use sealed enclosure for them but i want vented enclosure or LLT.
Any suggestions about volume and port?
What frequency range do you wish to get out of them? Do you have limitations on cabinet size? Subwoofers are always a compromise between size, efficiency and low frequency cut off.
If you have four woofers, you could distribute them over the room to get a more consistent sound across the room.
