vendor for solid core copper wire?
Hey all, I am looking for 18g solid core teflon insulated copper wire. Anyone know of an inexpensive supplier? I have been looking for a while with no luck. Do not want tinned or silver coated, most I find seem to be one of those two.
I bought off the reel from them and while I could be mistaken, it certainly looked and acted like teflon. Extreemly tough and hard to get off. If I'm mistaken, I was mislead and appoligize. Easy enough to send them a mail. They are quite responsive and eager to please.
Teflon can't be applied to bare copper (I don't remember the reason why). Copper has to be plated with silver before putting the teflon on.
So if your wire is copper under the insulation, then its not teflon.
BWP....
I have stock on the 18 Awg Solid core Teflon/PTFE but silver coated
at .35ft...
Why would you not want it silver plated and just bare wire, I have never
seen it in my searches for wire. What would be an advantage? or disadvantage ?
Steve @ Apex Jr.
I have used homegrown's wire, that is basically what I am looking for but a little bigger. May also also make some cables with the silver plated wire before I write it off, just seems that mixing materials that have different conductive properties should be avoided if possible. I am open to other coatings if they are out there, anything that is easy to work with and helps eliminate corrosion. I will check out the wire at the link provided, a bit spendy but beggars can't be choosers I guess.
