hi there, i've seen new t/s paramater calcs. for LE. on atlas 12 for low, and high Q settings but, what about the LE. at mid Q with 1.5 ohm resistor? has anyone calculated for that yet? as differences here seems to effect the response curve in WINISD PRO. thanks, crippledchicken
Question : Does Le really matter for subwoofers?If you filter between 60hz and 120hz,no.
http://www.google.com
http://www.adireaudio.com/Files/TechPapers/DualVoiceCoilWiring.pdf
http://www.geocities.com/f4ier/dvc.htm
