A rare opportunity
I have a few modules left over from when I sold my SA-01 and MA-01 amplifiers which are from the NC***MP range of Ncore modules from Hypex.
I have these modules, all unused.
1 x NC250 MP - £130 - Datasheet - this is a single channel 250W module
1 x NC500 MP - £180 - Datasheet this is a single channel 500W module
1 x NC122 MP - £175 - Datasheet - this is a 2 channel 125W module
2 x NCSA500MP - £140 each - Datasheet - these are 2 channel 400W + 100W modules designed primarily for active speaker projects
1 x NC100HF - £30 - Datasheet - These are single channel 100W modules designed to daisy chain from the main NCxxxMP modules above to drive tweeters in active applications. Missing the cable set but I will either find it, or show you where to get one.
2 x MP-DSP main - £50 each - these are the DSP boards used in the Hypex Fusion DSP plate amps. You could build your own fusion amp using the NCxxxMP amp modules
1 x MP-DSP DigIn - £50 - this is the optical, coax and AES/EBU input board for the above MP-DSP
If you want all of them you can have them for £700. I will also include the handy little evaluation board I have which lets you test the modules easily.
UK based postage will be £9 via UPS - happy to ship elsewhere at cost though.
These modules could be paired with the cases from Ghent https://www.ghentaudio.com/collections/hypex-ncxxxmp-series to make a really quick project
Hi, looks interesting.
I have a lot of Fusion amps in my cinema already but improvements would be welcome.
Are the dsp modules set up for 3 way or 2 way and are they the newer fir capable ones?
Those DSP modules are sold unfortunately. They were all 3 way though and were the older non FIR versionsHi, looks interesting.
Thanks. I don't agree though. The prices are around what the trade prices are and they aren't available to non OEM customers.Hi
Your asking price are high but at least it gives the DIYer the opportunity to hear what the Ncore sound is all about.
