Wow… this really, really takes me back…
I had a friend that for whatever reason, just thought wirewrap was the kitten's mittens. Used it for absolutely everything, even when it seemed to be a 'stretch of the purpose'. Yep… we made tube amplifiers and everything between with WW.
However, after much experimentation, it became clear that wire wrap was only good for the short term, by itself. If the piece of built-stuff flexed much, then eventually oxidation would set in and make some one of the hidden dozens-to-hundreds of connections vexingly noisy. And never when debugging.
We tried the "power wrap" thing that was popular for awhile (that didn't require stripping of the wire first, but used tension so tight that it cut thru the wire wrap insulation on the corner posts). Didn't help.
Ultimately we found that once a WW circuit worked, and it was time to "set it", that soldering all the posts was fast and easy, especially if one used multicore rosin solder, eutectic 63–37 type AND did so before the poor wire wrap wire began to oxidize. Tho' its now 45 years later, Vince still has (and uses) some of our mid-experience builds. Nuvistors, baby. The only tube socket we ever found that for an eye blink of time had wire wrap posts. Made by Amphenol Aerospace or Cinch I think. Don't know. Too far back.
GoatGuy
