Does anyone know of a reason not to use BNC's and decent coax as the wiring throughout the system?
Is there a reason why I haven't seen a single piece of audio equipment using BNC's?
If the system is DIY, I don't see a reason to use the industry standard of RCA connectors.
Of course, I'm sure there is a reason why I'm wrong.
Please indulge.
-Dan
Please indulge.
-Dan
I've been trying to get people to use BNCs on digital cables, which is what they should have been using all along, for over 12 years. Look where that has got me.
Jocko
Jocko
Jocko et al:
My Cambridge Audio D500 SE has BNC Digital out.
So your efforts haven't been totally in vain
BNC connections
I've tried BNCs and confidently advocate them for all DIGITAL connections. Make sure that you use 75 ohms cable(good quality RG59) and BNC connectors and not the 50 ohms variety. It makes a difference!! The 75 ohms "crimp" connectors by Amphenol are very good and gives the "audiophile" variety a good run for their money.
I've got mixed results for analog signals, with very good resolution but the sound is somewhat thinner and sterile. Vocals seems to lack "emotion". I find traditional copper co-axials or copper ultrafine wires (read Allen Wright's cable cook book. You'll be surprised at the results!!) much better in this application.
ckt
ckt
where is the difference in using RG58 or sth. like that, and oldfashioned copper coax for the analog NF audio signal? if the HF cable is good for very few damping a signal at 2 GHz, why should it cause any loss at 20Hz - 20kHz ?
Did anyone measure the effects on different cabletypes?
RG58
Till,
If fact, I used RG58 (50 ohms) with gold plated Amphenol 50 ohms BNCs for anolog signals and as I've mentioned, there is actually no loss in signal but it appears that the music as a whole becomes a higher pitch as if the whole audio spectrum has gone an octave higher. Details are actually excellent and vocals seem to come across very clear but does not have the "bloom" of normal good interconnects. Some audiophiles termed it as "less involving, sterile etc" or whatever they want to call it. I believe this effect is caused by the cable impedance rather than loss. Perhaps you can try it out and let us know your results?
ckt
Till,
ckt
- General Interest
- Everything Else
- Using BNC's as interconnects
