Using ARTA Spectrum Analyser effectively
I'm trying to learn how to use ARTA's spectrum analyser. I new to all this and could use some help, both with respect to ARTA and the art of noise analysis itself.
I have an ESI Juli@ sound card and I am running ARTA under Crossover on a Mac Pro. I've done the loop-back testing and line sensitivity calibration to setup Audio Devices.
As an initial project, I am trying to examine the noise of my implementation of a balanced to single-ended line input (the "DUT") for an amp build project. I am using a Samuel Groner designed low noise pre-amp with a (nominal) gain of 60dB and have entered a gain of 1000 in ARTA's audio device setup. The DUT's inputs have been shorted.
As I am operating ARTA under a commercial implementation of Wine I don't have access to ASIO. I understand that I need, therefore, to ensure that the sample rate selected in ARTA's control panel is the same as the sample rate used by the Juli@ - set via a Juli@ control panel.
My first question relates to how to set the range for a wideband noise analysis, e.g. 22Hz-22kHz. I see that a low frequency cutoff can be set in Setup -> Spectrum Scaling. I also see how weightings can be applied. I don't, however, see how the upper frequency is set. I assume also that the RMS figure displayed in red is the wideband noise measurement computed - correct?
I understand that to relate a (singular) wideband measurement figure of, let's say, -120dBV to the noise spectral density I see in the graphic when PSD/dBV is selected in Setup -> Spectrum Scaling I need to divide it by the square root of the measurement bandwidth (e.g. 21,978Hz). That is a -120dBV RMS value will have a chart with values roughly averaging -163dBV/rtHz. Correct? My presumption is that the gain of the pre-amp is already taken into consideration and that the RMS value is "referred to the input". Correct or do I need to factor in the 60dB of gain somehow?
Any help appreciated. Thanks in advance
Steve
Q1. Right click the FFT graph, you will see the dialogue box.
Hi. That's for the graph setup. (Otherwise accessed via Setup->Graph Setup.) Are you saying that the displayed graphical range is also the wideband measurement range?
