Hey there,
Trying to go SPDIF out of a Nexus 7 tablet to DSP without doing an audio conversion using a DAC. Slimport MyDP (usb-hdmi) then an HDMI to SPDIF converter? Am I spinning wheels or will this work? Or is there a better way that is relatively inexpensive?
I am currently using the Behringer U-Control UCA202 and am not happy with it. The best way i can describe it is the stage is not as wide, the highs aren't as clear and output seems muted. I can switch Spotify between Iphone streaming bluetooth to Mosconii 6to8v8 DSP and Nexus 7 wifi thru UCA202/SPDIF rather quickly and the bluetooth sounds much better. Streaming Bluetooth through the Nexus 7 is even worse. My thought is that SPDIF should sound better than bluetooth. I have searched a little only to get thrown into the realm of dirty usb power, DAC debates, and a whole bunch of other stuff I dont fully understand.
Hoping to get a clearer thought on how much more money I want to throw at this Nexus 7 project. Is it possible to get a better signal out of the tablet than bluetooth over the Iphone.
Thanks for your time
Nexus 7 appears to support USB OTG. My various Android phones interface OK to a CM103 or a PCM2706 (cheap USB -> I2S interface chips). Going through HDMI seems to be an unnecessary work-up.
Something like this gives you the choice of I2S or S/PDIF : L.UsbDigital?????? USB????? DTS???? I2S??-???
Thanks for the reply, I ordered PCM2704 a couple days ago. Looked into the 2706 and found a website which has a ton of info on DAC. Guess I wont be giving up on the tablet just yet, thanks again.
Audio Science Review (ASR) Forum
https://www.amazon.com/gp/aw/d/B00J5NCVZA?ref=ppx_pt2_mob_b_prod_image
