Hello everyone,
I am new to electronic design and I have to build an audio circuit for a college project.
I have to design and build a USB based hi-quality audio DAC.
After having a mini research I found the PCM2205 IC from Texas Instruments that does the whole job and more. I wouldn't like to use this IC though because it will be very easy. I may do it at the end but i would like to try to buid some of the part myself and not use one chip for the whole project.
I would like to find an appropriate USB module and build the DAC on my own(ideally).
Is the UM232R USB module appropriate for my project?http://www.ftdichip.com/FTProducts.htm
Can you suggest me any other way of interfacing a DAC to USB
I would really appreciate any help either on the USB part or on the DAC part of the circuit (part numbers, circuits, links, ...)
Thank you
Thank you
