I've just purchased a second UPL, this one with the Low Dist Gen option (3 years searching for one!) and am in the process of checking it out. Seller is ATE Test Equip.
I noticed there is no output from the generator unless I turn off the Low Dist option.
Is there something else that must be set up for this to work? I'm testing with the THD setup. The normal (non Low Dist Gen) seems to work, although the Ch1 voltage level reading is not 1.000V as with Ch2 (both are 1.000V on my other UPL). Maybe the calibration is off, too.
Anyway, just wondering if something's wrong with this unit.
