Up in smoke...
I am repairing my neighbor's girlfriend's car amp (MTX Thunder250D) and I need either a schematic or a cross reference part number. Whenever it is turned on two of the MOSFETS go up in smoke (connected in parallel). The parts are i think a TO-220 package and they have this written on it:
75339P
HO 27
The manufacturers logo is unrecognizeable because of the heat. Both FETs blew out the same leg. I called digi-key and all they could come up with is a Harrison MOSFET but they couldnt confirm an exact match. Thanks!
David
Are the MOSFETs in the output stage or in the power supply section? If they are in the power supply section, they others which are not blown should be the same, you could see about the exact number from there if it is too bad to read on the blown ones.
BeanZ
