Hi amigos,
I would like to use my Toroidal PSU 24VAC 300W with my TPA3251 (3E Audio AUMT-0140-2-A)
I need a unregulated audio-grade power supply to convert AC > DC
Since I have been living in France, I wonder if I can order this one and if it would fit :
Module d'alimentation lineaire double 4x 10000mF 50V - Audiophonics
I want to get closer to this project :
Hexbyte Hacker News Computers Build Your Own Professional-Grade Audio Amp on the Sort of Cheap - HexByte Inc.
The 24VAC would give about 33VDC, so it will work.
Thanks. But my question was rather about the power supply itself. Since My PSU is a 300VA (300W)
does it inspire you?
Since My PSU is a 300VA (300W) does it inspire you?
The electrolytic capacitors are likely of low quality.
Maybe someone in the EU could suggest an alternative board.
I thought EVOX and Nover capacitors were pretty good... hummm
Thanks )
The 24VAC input would give about 33VDC, so it will work.
Your transformer should have two 24VAC secondaries to use this board.
A single 48VAC center tapped secondary winding would also work.
Normally my single 24Vac should Also Work ?
The secondary of my psu is a single 24v
- Power Supplies
- [unregulated, audio-grade power supply] Please help
