A 6DJ8 is a ECC88 🙂I have some Amperex 6DJ8's that look IDENTICAL to these...
Mona
Thanks for the replies
maybe the best way to know what they are, would be to conect them to a circuit ,and try to measure the voltages in plate and cathode ? say make the grid voltages -1v ,-2v, -3v, and see the variation in the plate voltage ?
It appears to have a Philips-type glass seam on top so it should have an etch code near the bottom.
Post a Photo of the codes on the side.
Philips production codes
DJ PCC88
[FONT=Verdana, Arial, Helvetica]Cm [/FONT][FONT=Verdana, Arial, Helvetica]GA ECC88 [/FONT]
[FONT=Verdana, Arial, Helvetica]OP PCC89
[/FONT][FONT=Verdana, Arial, Helvetica]IP PCC189
[/FONT][FONT=Verdana, Arial, Helvetica]IX ECC189[/FONT]
DJ PCC88
- Tubes / Valves
- Unknown Tube
