Welp, I finally got my garage sale amp on the bench for internal inspection prior to a re-tube and testing and discovered exactly why my gal got it for $5.00 bucks!
Internally its actually very clean and tidy except a couple fried resistors! See Pics
Pic1
Pic2 Pic3
Pic4 schematic of 6l6 version
Pic5
The schematic of the 6550 model I have can not be located on the web. But the 6L6 version utilizes the same circuit board and is fairly similar.
I also noted a cap that looks to me as if its slightly swollen. Ive seen this on some lower end motherboards before, But never in an Amp.
My Questions simple(Kinda)
Noting the location of the 100ohm resistors. What would be the typical reason for these to smoke?
Bad Tubes? Perhaps overloaded output?
Shouldnt a fuse blow before this serious of an event?
Ok Thats 3 questions
As far as I can tell,, Everything else seems to be in order.
Gene
Pic1
Pic2 Pic3
Pic5
Gene
