Uni Project build
Hi folks, just new to site so nice to meet you all 🙂
Im currently in the last 4 months of a music technology degree and plan to do a speaker modification build as my final project.
I have recently purchased a cheap set of Jamo D 365 speakers to modify, initially i wanted to build a speaker from scratch but due to restricted access to workshops this was unachievable. The plan is to take a measurement of the speakers in their original state and then take a measurement after each modification process to document the improvements or vise versa.
The type of modifications i plan to do are as follows:
Driver replacement. Was thinking of going with Fane drivers as i have tested a turbo sound system and was impressed with the results.
Building a passive crossover
replacing all wiring and connections and adding speakon connectors.
Modifying the cabinet.
Adjusting cabinet damping.
Constructing a heat sync to reduce thermal compression.
One idea i have is to counter sync the mid driver and horn load the cone driver, similar to turbo sounds mid device although this may be difficult 😕
Anyway i was wondering if you kind folk of diyaudio could sugest other quality driver makes, websites to purchase parts and accessories and ideas that i could research to complete my project. Any advice or help would be greatly appreciated 🙂 Forgot to mention i will only be modifying one speaker due to being a skint student! lol also i have a budget of around £250 thanks
download Unibox (free) to help with modelling the cabinet
download ARTA (free) & use a simple jig to help with measurement
Re: driver replacement, model the existing driver & the replacement candidate in Unibox before you do anything, replacement isn't simply a matter of swapping drivers,
& the Jamo is probably well designed in the first place...
To do well all the things you suggest would involve a considerable amount of learning, I suggest you don't be too ambitious for the time you've got...
