I’m modifying a 4-way 12AX7-based crossover and measuring unexpected attenuation in the low pass stages.
LTSpice simulations show no attenuation.
For example, this is the 125Hz low pass stage.
The 35Hz low pass stage is similar.
Component values are from TCJ Filter Designer.
For reference here is the 35Hz high-pass stage:
The high pass stages (there’s a 35Hz high pass and a 125Hz high pass) show approximately 0.3dB or so attenuation in the pass band as you’d expect.
The 35Hz low pass and 125Hz low pass filters show 9dB and 7dB of attenuation respectively.
Here’s the 125Hz low pass amplitude vs frequency superimposed on the 35Hz high pass amplitude vs frequency:
Pete Millett mentioned problems matching 12AX7 low pass and high pass stage gains due to the high output impedance of the 12AX7 cathode follower but not to this extent.
Can anyone suggest what the problem might be here please?
Next step is to try a CCS in place of the cathode resistors to take ra out of the equation.
Before anyone suggests switching to a 12AT7 or 12AU7 I'm reluctant to do that because it would mean modifications to the power supply.
