Yup, I screwed up. Tried to rush putting on the finished baffle for one of the BIB's before I left home the last time, didn't come out right at all. Now I've got a 3/4" baffle that refuses to come off, the glue (Titebond, PVA stuff) has pretty much cured. I've tried heating the baffle with a heat gun, but maybe I just wasn't waiting long enough or it wasn't working.
What would you guys recommend for loosening a glued-on baffle? Maybe an iron would work?
Thinking the steam might do something...what about soaking down the top baffle with water and then heating it?
Thanks in advance.
Thanks in advance.
How about sawing off the sides, right up against the baffle with one of those flexible pull saws for cutting dowels flush? It would be slow as heck, but you'd only lose a kerf thickness worth of cab volume. I suppose you could use a table saw, but the kerf is more than twice as wide.
Take one of these and use a hammer or mallet to drive it between the box and baffle and then do than all the way around. Thats how I removed the one I glued wrong a few months ago.
kmj said:Take one of these and use a hammer or mallet to drive it between the box and baffle and then do than all the way around. Thats how I removed the one I glued wrong a few months ago.
You would have to be very very careful using this tool, if you don't want to damage the cabinet!
- Full Range
- Undoing wood glue...advice needed :(
