u/a capacitors
well ....not exactly
not always like that my friend ..... if this is some feedback capacitor and you make it from 150mf /25v to 1000mf 100 volts you may end up with an explosion .....
you need to know the application before you choose to add or remove something ....
it very nice that some amps can blow woofers 2 meters AWAY from the box!!!!!!! ..... its such a pitty though that woofers can only do that ......ONCE .... HE HE
good luck sport.... :smash: :smash: :smash:
Oh yey sakis, its ..the caps, are on the main boards, the main big daddy ones😀
used to be a 2200 uf, ive since replaced these puny examples with a 6800 uf, The bass is very pleasing now.....
the said caps to be replaced caps are a subsiduary little brother just up the rear!😀
