Exactly the same as connecting two drivers without crossovers in series, see: speakers in series.
The only difference is that the impedance seen before the crossover has a different characteristic than a driver without a crossover.
Connecting in series won't necessarily do anything 'bad', but it likely will change the frequency response for the worse. Also, connecting two different multi-way speakers in parallel isn't advised either, because the phase response of each multi-way speaker is unlikely to match so there will be partial cancellation.
