WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
Twisted AC is better than poor "DC" in straight lines... without a giant cap or a MOSFET pass filter (or an SMPS in the first place), most times you're better off with well twisted wire and AC current.
Twists will reduce/prevent both pick-up and outgoing interference, for DC heater wires only pick-up is possible of course as DC doesn't generate changing magnetic fields. Noise pickup on the heater is unlikely to have any effect for an indirectly-heated device.
It certainly makes the wires a lot stiffer and therefore easier to route. If the wires were thick (nice margin wrt to ampacity required) and solid (as opposed to straned) and otherwise thoughtfully restrained, I bet untwisted would be ok.
As was and IS good practice when running heater wiring, particularly with preamp circuits, twisted pairs AND routing/dressing intelligently is the best result.
Down against the chassis, away from signal wiring.
It's the way that its been done for decades.
