What is the TUBE SOUND ?
I think the biggest contribution comes from small distortion
such as 0.5% THD.
To generate 0.5% THD, I propose to install a pre processor before
solid state main amp. I did simulation with the attached circuit
schematic using 12B4A on TINA-TI simulator. The results are as follow:
Voltage Gain = 4
THD = 0.512% @0.4Vrms output
Circuit Description:
Power supply: Laptop PC's AC adapter, DC 12V out put for both
plate and heater power supply.
I eliminated the Cathode By-pass capacitor as it affects to
degrade the sonic. 300mA of 12B4A's heater current is
merged into a cathode resistor with the 12B4A's plate current.
Resulting. only 2.2 ohm of the cathode resistor is enough and
the negative feed back due to cathode resistor is minimized
I have not yet assembled the actual amp of this circuitry.
Simulation only at the moment.
'73 de JA2DHC
such as 0.5% THD.
Voltage Gain = 4
'73 de JA2DHC
