I have seen lots of tube circuits with solid state rectifiers, but I have never seen the opposite. Is there a reason to not use a tube rectifier in a solid state circuit?
Well, considering typical effective resistance is in the range of 100 to 600 ohms, I think that pretty well answers it.
If you want to make a high voltage, low current SS circuit, with output transformer to match the high current speaker to the amplifier, you are welcome to do it. Kind of redundant though.
Tim
Tim
It's not easy. Obviously the 'standard' tube rectifiers are not really suitable for currents in excess of 250-300mA which rules out power amps. For preamps/cdplayers/dacs vacuum tube rectifiers should be fine but would likely drop a lot of voltage. Unless regulation is involved this may be a problem. Mercury rectifiers, otoh, are readily suitable for preamp duties.
So, why haven't i tried it? I guess i still haven't found a SS circuit deserving of all this loving care. A tube powered DAC would certainly look deliciously perverse if you're into digital.
analog_sa said:So, why haven't i tried it? I guess i still haven't found a SS circuit deserving of all this loving care. A tube powered DAC would certainly look deliciously perverse if you're into digital.
The circuit in question I was thinking about is for a NOS DAC. The current it draws is pretty small, certainly les than 100mA ... maybe I'll look into it?
Tube rectifiers...big, expensive, voltage loss up to tens of volts, low current, low efficiency, need heating, short life...
In high power solid-state circuits, the current is too small; in small signal ones, the voltage is too high.
And it's not like tube ampilfiers, which benefits the sound.
dsavitsk said:I have seen lots of tube circuits with solid state rectifiers, but I have never seen the opposite. Is there a reason to not use a tube rectifier in a solid state circuit?
Oh, yeah? You sure about this?
Go for it. In any case you'll have lots of regulators so uncertainties about voltage drop are less of an issue. It may be a good idea to use some kind of high voltage preregulator as it will allow tube rolling without undue excitement 🙂
- Power Supplies
- Tube rectification for SS cicuit
