Hallo, do you have any idea about a good tube preamp to drive CORRECTLY my beloved Aleph 3.
I think that a tubed pre could be a little better than Aleph P or L, don't you?
It has to have:
simple circuitation
stepped(discrete) attenuator
two out (maybe i'll use biamping)
class A
fantastic sound,of course.
Thanks all.
It has to have:
simple circuitation
class A
Thanks all.
spersanti276 said:I think that a tubed pre could be a little better than Aleph P or L, don't you?
I think that tube pres and Aleph P and L have the same values in different ways. I think SRPP or Marantz 7 type tube pres are simple enough for diy.
I'm sorry for the misunderstanding, I forgot that this is a DIY
FORUM.
I didn't mean to build a tubed preamplifier by myself (I'm not even
able to solder!), I need an advice for an existing one with those
peculiarities.
Thanks in advance and sorry for my bad English.
Stefano
FORUM.
peculiarities.
Stefano
DocLorren said:Grey,
You are still invited to come up with your tube pre. Enlighten us!
Come on ..cough it up!!
I did a quick run-through of the group of schematics I thought it was in and didn't find it. I have many other places to look. The problem being that it was several years ago and I generate a lot of schematics during the course of any given year. Some I try. Some I don't. A lot of them are variations on circuits I'm really serious about. For instance, there are probably close to thirty files related to the amp I've been working on, and it's only going to get worse as time goes by, because I've got at least two more major branches that I want to explore if/when I have time and money. On the other hand, I'm on the verge of getting burned out on this circuit, so I may give it a rest and hit the phono stage for a while just to give the amp-related portions of my noggin a rest (and to avoid having to face the cost of heatsinks and a "real" chassis--at least phono stages are manageable in terms of power supplies and heat dissipation).
Grey
Grey
I do happy listening with a Combination of ZEN V4 with a Norwood-Still Tube-pre wich uses the 12B4A (AXpress ...?)I put the Stepped Attenuator of 100K after the Pre instead of in Front.I like the "non Sound" and clearness without "Edges".Nice!
Caution:Use only with a glass of Ardbeg(W.)!!!Chears
I have aikido driving an abreviated f4MikeW said:I built an Aikido. It sounded very nice. Not better than the Pass pre-amps but different.
Maybe I don't understand the question? Do you need voltage gain? How much? Aikido has many variants and "sounds" due to this choose your favorite tube stuff...
I need a buffer like B1 for the attenuator(volumme) and my "ZV8" like pre (F3 with 300ohm load, driving 10k)
- Tube preamp
