Wow, I'm amazed at the 'sound advice' that arrives in such a short time from this group! MANY THANKS to all who contributed!! I should back up a bit and mention that indicated that I'm kind of 'hooked' on old separates...like the Dynaco, Eico, and Heathkit power amps and their respective pre-amps. However, from a 'pre-amp' perspective, I've found that all those old units DID contain a phono stage....which I do not need or want. And, they all had multiple inputs....which is also a function that I don't need. At best, I'll do a simple toggle switch for two sets of inputs...the classic 'A' & 'B' thing. My plan is to drive the thing with a CD player......and perhaps down the road add XM or Serious radio. I attempted to subscribe to a few PC based music providers, but didn't get much satisfaction in the programming. And, after having Serious in a company car I had while employed.....I did enjoy some of the talk-show stuff on that venue as well as the music channels. But....for now....it's just the CD player. And...if any this is any help, I hope to build a set of 6V6 mono-block amps AFTER I build this pre-amp project....and the pre will be used to drive those amps. I've not seen any really good examples of what any builders did with the 6V6 tube in most anything other than console or suitcase type amps...... Most all the Dyna, Eico and Heath stuff all seems to revolve around either the EL-84 or on to the 6L6/EL-34. So, I'll be looking for a GOOD yet Simple circuit for that amp next!! I do have transformers....so good to go there! Again...thanks for all the help! I'll check out all the leads (no pun intended). Tom D.
