Now that I’m retired, I’ve taken up the hobby of restoring vintage radios and audio equipment. I’m new to tubes, despite being in the electronics industry for 32 years. I’ve worked on a few 30’s radios, and now a 50’s mono and 60’s stereo tube amplifier. I find it interesting that the amplifiers have negative feedback around the output transformer. (I didn’t think this possible, but evidently it is.) Does this change the speaker output from a current source to a voltage source? If you remove the speaker from a 30’s vintage radio, the tube pushes the audio current though what now looks like a large inductor. The voltage across the transformer primary goes wild and can damage the tube or transformer. What would happen with the feedback design? Does the output voltage stay the same when you remove the load?
Our company’s early transistor car radios had the same problem. Our output design had a single large PNP germanium transistor operating class A. The collector had a large choke going to ground with the speaker in parallel with the choke. If you turned up the volume with the speaker disconnected, the high voltage across the choke would fry the transistor.
Bobby Dipole
Bobby Dipole
