What higher filament current?
Your tube: 0.88A, . . . At 6.3V???
807: 0.9A at 6.3V
That is a close as you get with production tube variances.
The same filament current may, or may not, mean it is an 807 (a 6L6 has 0.9A filament current, but a 6L6 is not an 807).
If you think a 6L6 is a good replacement for an 807, just make a 75 Watt CW transmitter, then you try and tune up the Pi filter to a very reflective antenna (reflective, as in it is either 10 Ohms or 300 Ohms reflected impedance to the transmitter). Zap!
The photo looks like 5 pins at the base.
807: 0.9A at 6.3V
807 = Г-807 = GL807 = RK-807 = A4051I = ZA3496 = CV124 = 5B/250A = VT199_GPO = 5S1 = CNU-807 = 38807 = 4Y25N = VT-100 = QE06/50 | |
10E/11441 ; 4Y25 ; ATS25 ; ATS25A ; ATS25N ; CV1364 ; CV1374 ; FU-7 ; HY61 ; NL807 ; P17W ; QV05-25 ; RK39 ; UY807 ; VT-219 ; VT60 ; VT60A ; WL-807 CV1060 ; CV1572 ; QE06/50W |
- Tubes / Valves
- Tube identification
