I have purchase the Broskie PS1 HV-LV power supply and am having issues with the HV side. I have sent a couple of emails to the John but have not received any response so I was hoping someone could assist.
The issue I have is, every time I apply the ac voltage to the boards ac input I get sparking at the base of the LD1085V regulator and it ends up passing the whole DC voltage to the output.
The circuit looks simple but I’m even simpler when it comes to understanding these circuits. John say the “The PS-1 regulator uses an LD1085 as the voltage regulator and an IXCY 10M45S constant-current source to shield the LD1085 from the high-voltage. The LD1085 is nested in its low-voltage span of just a few volts, while the IXCY 10M45S sees the bulk of the input/output voltage differential. Consequently, the IXCY 10M45S gets the heatsink, while the LT1085 is left naked.” But in my case, this doesn’t seem to be working.
I have checked every component numerous times and they all seem to be fine, resistor are the right value, diodes and capacitors are the right way around, diodes are still good etc. D5 is missing in one of the images but that’s because I took it out to test it.
The board came with the obvious after production work to the area where the LD1085 & IXCY 10M45S are located, the vias have been cut way to stop them touching. I only noticed today that there is a little bit of copper showing where the alternate mounting location is for the IXCY 10M45S, but there isn’t a dead short between the 3 via’s. See image HV 4. I removed the LD1085 (it was dead anyway) to take the photo. I have left the IXCY 10M45S in place hoping it is still ok.
After removing the LD1085 I have measured between the IXCY 10M45S terminal in the hope that these measurements might mean something to someone wiser than I.
A-K = 21ohms = Is this too low?
A-G = 18.3mohms
K-G = 18.3mohms
I’m wondering if the 300ish volts could be arching due to the work around the via’s?
All thoughts/help is greatly appreciated.
A-G = 18.3mohms
K-G = 18.3mohms
