Hi Guys,
A little tutorial pls. My experience has been with a couple of EZ81, 5u4g.
Am researching PS for my next project. I've seen the use of 4 Tv diodes to build a bridge rectifier. Question if I already have a transformer with 45-0-450 acv, can I use it to build a full bridge supply, if so how do I go about connecting it ?
Also is there any advantage to be had aside from much lower cost of Tv Diodes
Thank you
Thank you
There is a major disadvantage to a bridge made from 4X vacuum diodes, a doubled forward drop loss.
Bridge rectifiers are used with a simple, not CT, winding. Assuming a "typo", your power trafo is 450-0-450. To use those low cost TV tubes (probably damper diodes), continue with the FWCT topology you're familiar with, constructed with 2X of the TV bottles. Just tie the cathode connections together.
Hi Eli,
Thank you kindly & apologies for the typo error. Btw any good recomendations for tv bottles that can supply around 200-250 ma of current ?
Thanks again
Thanks again
6D22S is the only real choice IMHO. And they still make them I think.
https://shop.ehx.com/catalog/addimages/6d22-svetlana.pdf
Numerous damper diodes had current ratings over 250 mA. The common 6AX4 would barely make that with a pair; 6AU4s will do 350 mA with 25V drop. There were higher current ones; but not as common. 6DT3 has 20V drop at 680mA...
But these may not be so common outside the US. If you were in the US, I'd send a bunch for the postage...
Another "gorilla" among damper diodes is the 6CJ3. Keep in mind the fact that the DC current rating is for a single bottle.
If you're dealing with a simple winding and bridge rectification is a must, go hybrid. Vacuum diodes in the "hot" legs and SS diodes in the "cold" legs yield performance that's dominated by the vacuum diodes, without incurring the doubled forward drop penalty.
Thanks Guys for the recommendations.
Btw Eli I saw schematics of this hybrid bridge that you mentioned.
What's the advantage & can I use this with my CT transformer ?
Thank you again Gents
A common 5AS4A or even a 5U4GB rectifier is capable to over 1 amp in tube equipment.
Surely enough for full wave duty.
Why bother with 4 diodes?
Hi Wise,
Yes I understand, one thing that interest me is the slow turn on which is a good thing as Tubes are going for crazy prices these days not to mention rectifiers tube as well.
Thank you
Thank you
How many volts B+ do you need?
How many milliamps B+ do you need?
Using a 4 tube bridge rectifier to rectify a 450-0-450 transformer (and the whole 900V secondary), and a capacitor input filter,
you will get about (900V * 1.414) - 2 rectifier voltage drops.
That will be about 1270V - (60 to 120V for two rectifier drops).
Using a 2 tube in full wave mode, using the center tap, and secondary 450-0-450, and a capacitor input filter you will get about (450V * 1.414) - one rectifier drop.
That will be about 636V - (30 to 60V for one rectifier drop).
If you use a choke input filter (with a swinging choke), and the choke has at least critical inductance for the current drawn, then replace the 1.414 numbers above with 0.9.
Recalculate with 0.9, and you will get the voltage output.
In order to power a given milliamp current, the full wave rectification using the center tap will present an easier load on the secondary, versus a bridge rectifier across the whole 900V secondary.
We are back to how many volts and how many milliamps do you need?
And, what is the transformer secondary current rating?
Hi Summer
Yes your correct, that's why I ask if its possible to use my CT Trafo to build a full bridge supply. Since I can't I'll stick to full wave with 2 tubes. 636v is ok as Im building a regulated supply.
Thank you again
Thank you again
The answer you may be seeking is no, you cannot use a 900V secondary with a bridge rectifier as though it were a 450V secondary.
- Tubes / Valves
- Tube full wave rectifier vs tube full wave bridge rectifier
